Anyone else having problems with HHR surging
Old Jan 27, 2018 | 12:31 PM
bookdoug's Avatar
Is there a difference between flashing a trans and reprogramming a trans? The dealer
was suppose to reprogram my trans. It is shifting at different RPMs now and getting about 7 mpg better mileage.
Old Jan 27, 2018 | 12:32 PM
Originally Posted by bookdoug
Yet I have another different problem. 06 Chevy Equiox won't start when it is cold, 32 degrees or colder. It won't start Sunday morning, temp was 17 degrees. I jumped it from the HHR and it started just fine. Yesterday won't start at 21 degrees. 5 hrs later outside temp is 42 degrees and it starts just fine, w/o a jump. I took it to AZ for a battery check and they determined the battery, starter and alt, were working and in good order. I put the SUV in the garage last night and it started just fine, temp about 40 degrees.
Any suggestions?
There have been many times that AZ(or whoever) told people that their battery was "fine", when it was not. If it doesn't start, then you jumpstart it, and it does start... and extreme cold... I'm thinkin' battery.
And like Whopper asked - does it crank or not? I'm guessing it cranks, but slowly?
Old Jan 27, 2018 | 12:40 PM
bookdoug's Avatar
car won't start when cold outside
btw - NO, it wouldn't even crank. All the dash, and dome lights came on but it didn't crank. But started up with a jump and by itself. It's a beautiful 42 right now and it started right up.
Any ideas why?
Old Jan 27, 2018 | 12:46 PM
Now we get the whole story. Throw a voltmeter on the vehicle and check the voltage before and after trying to start it. How old is the battery?
Just get a new battery.
https://www.lifewire.com/why-do-car-...go-dead-534855
Old Jan 27, 2018 | 12:52 PM
If you could find someone to give the battery a comprehensive test, and give you a printout of the results, that would help us know if the battery is or isn't the culprit.
Old Jan 27, 2018 | 12:58 PM
  #26
The printout from the test should show the currently (no pun intended) available capacity in Cold Cranking Amps. Compare that to the rated amount labelled on the battery.
Old Jan 27, 2018 | 01:20 PM
  #27
bookdoug's Avatar
Any ideas why?
Old Jan 27, 2018 | 01:59 PM
  #28
I give up - I'm out. Obviously you don't even bother to read the posts from those trying to help you.
RJ - wanna close this as it just is not getting anywhere?
JazzDad
Jul 9, 2019 08:53 PM
Kit
Feb 7, 2015 05:11 PM
DANNY HUNTER
Nov 6, 2012 01:26 PM
frdfandc
2.0L Performance Tech
0
Mar 25, 2012 07:19 PM
Toadady
Apr 16, 2008 09:38 PM
