Automatic transmission dipstick on 2.2?
Old Jun 12, 2007 | 10:28 AM
Lone Ranger's Avatar
Question Automatic transmission dipstick on 2.2?
Where is it?
Old Jun 12, 2007 | 10:32 AM
shaginwgn's Avatar
There is no transmission dipstick because the transmission is a sealed system.
Old Jun 12, 2007 | 10:56 AM
Goose's Avatar
Originally Posted by Lone Ranger
Where is it?
Welcome to the Club
I spent quite a bit of time looking for the damn thing wondering why I couldn't find it
Goose
Old Jun 12, 2007 | 11:40 AM
solman98's Avatar
Is this true?
If so, glad I got a stick....
Old Jun 12, 2007 | 11:44 AM
oneton's Avatar
You have a sealed battery, sealed rear wheel bearings, where is the dip stick on your M/T so you can ck it
Old Jun 12, 2007 | 11:58 AM
solman98's Avatar
The clutch recieves fluid from the brake reservoir. All manuals (since the 1980's at least) use a reservoir to check fluid, some just share with other components. Older manuals used "dope" or grease.
Big differance between a tranny and a sealed battery or bearings.
Old Jun 12, 2007 | 12:08 PM
There is no way to manually check the fluid level in the automatic transmission? I hope there is at least a sensor that illuminates a warning lamp when/if fluid gets low, etc.
My HHR is new, I just like to know where all the routine maintenance check items are located. I did notice no apparent need for lube jobs, because the fittings are sealed and no zirk nipples anywhere. That's cool, I guess. Can you tell I'm Old School?
Old Jun 12, 2007 | 12:23 PM
Black Rose's Avatar
There is a way to check it, but it seems to be a dealer tech only type of thing.
My Malibus also had a sealed automatic transmission, and they were forever showing me my "dirty" transmission fluid that they were willing to flush for only $120. NTFL
Old Jun 12, 2007 | 12:31 PM
Thumbs up
Well, at least I can still do the Old School oil dipstick check every once in a while.
Old Jun 12, 2007 | 01:17 PM
Don't feel too bad, I just spent 10 minutes looking for the power steering fluid cap!
