Automatic transmission dipstick on 2.2?
Old Jan 21, 2014 | 01:21 PM
  #31
Laco's Avatar
Originally Posted by donbrew
The car must be level and the ATF must be at 104F and the motor must be running. Then remove the level control plug.
Why worry about the ATF level to begin with? Where could it go? Onto the ground is the only place.
Most manufacturers have realized that now. Plus with synthetic ATF being long life.
Don't know if its still the case on these transmissions, but years ago there used to be a vacuum modulator valve, on the transmissions. I have seen those go bad internally, resulting in engine vacuum sucking fluid out of the transmission, into the engine intake. No leakage on the ground with that issue, just that mysterious loss of transmission fluid. As I said, I really do not know if they are still used or not.
Old Jan 21, 2014 | 02:07 PM
  #32
db/sb's Avatar
As I recall, depending how severe the breach in the vacuum diaphragm in the modulator was, it wouldn't be all that 'mysterious' considering the exhaust smoke that would cause. I don't think the HHR trans is has one, however.
Old Mar 10, 2014 | 07:31 PM
  #33
Raysrocks2's Avatar
I looked for more the 10 min
Old Mar 17, 2014 | 09:43 AM
  #34
cc732's Avatar
Last time I ever saw a modulator valve was on the remaining THM 350's (rear driver) we made in Windsor before we re-tooled to the THM 125 (front driver) in 1982.
THM 125's and the 4T40 & 4T45E didn't need modulators due to the different clutch pistons, check valves and valve body changes.
Modulator valves went out of style with the glass T Tops.
They are sometimes used on R 400 heavy pick-up truck diesel apps, I think.
Clare
donbrew
Drivetrain (Excluding Engine)
22
Mar 3, 2024 08:06 AM
donald cole
Jul 17, 2012 10:50 PM
humbledservant
Apr 27, 2012 10:44 AM
sbishop1331
Dec 28, 2009 06:40 PM
JoeyFeduka
2.0L Performance Tech
13
Nov 5, 2009 07:50 AM
