Backup Light Problem
Old Mar 29, 2019 | 12:02 PM
Lucas James Keech's Avatar
I'm having a problem with my left backup light - it's not working. I just got done wiring a backup camera to the wires that provide the light with power. I didn't even splice the wires, I just peeled back some insulation and soldered the backup camera wires on. It is worth mentioning that the backup camera is still receiving proper voltages. Maybe I blew the bulb somehow?
2006 hhr
Old Mar 29, 2019 | 12:39 PM
that's the first guess
second would be you got some wires mixed up and it is shorted OR didn't wrap the solder joint
Third compromised the ground wire for the light
Old Mar 29, 2019 | 12:47 PM
I did insulate it pretty well (definitely nothing is touching.) I guess I'll just try a new bulb soon.
Old Mar 29, 2019 | 12:49 PM
Cat Man HHR's Avatar
Could explain what color wire from the car you soldered the camera wire to to get power ?
Old Mar 29, 2019 | 01:08 PM
Well, both actually. I was assuming green was the hot and soldered the red wire to there, then black to black. I'm using a wireless transmitter for the camera.
Old Mar 29, 2019 | 01:28 PM
By this you are correct.
Old Mar 29, 2019 | 02:08 PM
It was the bulb. Filament is definitely blown, thanks for the help!
Old Mar 29, 2019 | 02:33 PM
Light green is bat black is ground.
depending on where you grounded the camera, you might look to see you didn't lose the wire connected to ground under the lamp.
Old Mar 29, 2019 | 03:55 PM
Problem solved.
J.daryl
Mods - Exterior
Apr 29, 2016 09:57 AM
Thoughtninja
May 8, 2015 02:34 PM
indy8six
Aug 11, 2009 09:11 AM
