Battery Draw when Engine Running
Old Jun 16, 2022 | 11:50 AM
tr34's Avatar
Okay, I haven't driven the car since Friday, much longer than I had it sit for when the battery died (only had it sit over the weekend when it died). The battery is still okay, I have power to everything. Not sure what made the battery die before.
Old Jun 16, 2022 | 12:24 PM
greg8453's Avatar
You probably had a light on or you may have a bad switch. The switch can turn on or not turn off from door closing.
Old Jun 16, 2022 | 04:02 PM
The interior lights are "supposed" to go off automagically after 5 minutes after key removed & driver door closed.
Old Jun 16, 2022 | 04:09 PM
The radio stays energized for 10 minutes. As do the windows after the key is turned of but before the doors are opened.
RAP .. Retained auxiliary power.
Old Jun 16, 2022 | 07:53 PM
The interior lights are on a circuit that dims out, different from RAP but close. Fun to watch when you get home late.
MLDD
Feb 24, 2022 09:49 PM
Cycara
May 21, 2020 09:08 AM
venomlegionsHHR
Jun 9, 2012 06:52 PM
Colin
Apr 26, 2012 06:36 PM
Jeff'sHHR
Sep 28, 2009 12:47 PM
