Battery issues
Old Mar 20, 2013 | 11:20 PM
emd820's Avatar
Battery issues
I have a 2009 with 4000 miles in Indian Shores FL. It sits outside with a solar charger and a neighbor starts it weekly. I live in the Chicago area and only get there 3 to 4 times a year. I was there this Feb 6 to Feb 21. I took the solar charger off and used the car everyday. It turned over fine. On the 21st i wanted to fill the car with gas, but it wouldn't crank. Only that terrible clicking sound. Any thoughts? I figure it's either battery or charging system or both. You mean to tell me that a battery lasts longer in the freezing cold of Chicago?
Where should I buy a battery in the St. Pete Clearwater area. What battery manufacturer? Thank you
Old Mar 21, 2013 | 10:17 AM
SpaceCowboy's Avatar
i would run some diagnostics first...get the battery checked and the charging system
Old Mar 21, 2013 | 10:29 AM
solman98's Avatar
Batteries today can work today and be dead tomorrow. As stated, have it checked out. Heat and cold are hard on batteries. Instead of using a solar charger, why not just use a maintainer?
Old Mar 21, 2013 | 10:52 AM
emd820's Avatar
I cannot use a maintainer as this is at a large condo complex. No outside outlets. Solar charger the only way.
Old Mar 21, 2013 | 06:09 PM
Snoopy's Avatar
Solar chargers are ONLY good for maintaining an ALREADY FULLY CHARGED BATTERY. That should have been explained in the literature that came with the solar charger. They work like a 1 or 2 amp trickle charger, to MAINTAIN the battery. They do not charge a weak battery.
Unless of course, you have one heck of a solar charger.
Old Mar 21, 2013 | 06:37 PM
skyline26's Avatar
^^ x2
Old Mar 31, 2013 | 11:04 PM
RJ Vleck's Avatar
Hello from Houston. My first post ever on the site! Just had the same thing happen...car wouldnt start...no lights indicating a problem before hand. Got a jump and it started right away...probably a weak original battery....2009. Will get it tested tomorrow. Sure wish they had a guage that would tell you when the battery is getting weak or needs to be checked!
Old Apr 1, 2013 | 12:51 AM
Welcome to the site RJ Vleck.
you should do a proper introduction here...https://www.chevyhhr.net/forums/introductions-48/
Old Apr 1, 2013 | 10:56 AM
Laco's Avatar
I have been told by battery shops, that solar charging will kill batteries pretty quickly. You might consider finding some inside storage for it with power so you can run a battery maintainer, which is the only way to keep the battery alive for long periods of time. Check for RV storage facilities.
Old Apr 1, 2013 | 01:06 PM
jay loukakis's Avatar
You need to check the battery voltage it can be done under the hood a cheap volt meter, if it way below 12 volts it will not start, as my mirrow lights were on all night and was readinf 8.49 volts, I have a jump start battery uniyt from Harbor Freight cost about $40.00, a real life saver.
LuckyLadySD
Jun 12, 2014 02:09 AM
gsl54
Jan 8, 2013 09:36 AM
Musky
Feb 23, 2011 10:50 PM
longhornss
Feb 27, 2009 01:15 PM
