BCM-fuse panel
Old Nov 20, 2015 | 05:03 PM
reelal's Avatar
BCM-fuse panel
Hi guys, reelal here and I have a question, I've called myself looking, a lot, but is the interior fuse panel and the BCM the same piece of gear and is there more on the back side of the BCM that I can't see. I've already learned a considerable amount from you guys thank you. by the way, I don't see but one relay on the front of this BCM and the OM shows three. That's the reason for my question.
Al
Old Nov 20, 2015 | 05:22 PM
My owners manual shows 3 relay positions. The diagram shows 1 with solid line and the other 2 with dotted lines. Even the description shows one of those spots as being "Empty".
Yes. I would say only 1 spot is used on your's.
Maybe another year, model or different equipped HHR gets that second relay.
Old Nov 21, 2015 | 10:06 AM
reelal's Avatar
Thanks Firemangeorge, my owners shows the fuse block but I believe it's upside down from the actual BCM in the car, maybe now I can trace the current flow. Thanks again.
GDZHHR
Oct 26, 2009 04:49 PM
Colin
Sep 29, 2009 08:46 PM
Pretzel
Tires & Wheels
Sep 11, 2009 05:25 AM
HHR4JK
Sep 29, 2008 02:01 PM
Lee3333
Feb 1, 2006 07:48 AM
