BCM inop. HHR SS
Old May 19, 2017 | 12:30 PM
Robert4's Avatar
BCM inop. HHR SS
Has anyone have their BCM quit operating normally. It seems some operates with a scanner but not traction control, keyless entry, and the such. If the BCM is bad that possible but a broken connection may be present. Any help out there. Thanks.
Old May 19, 2017 | 12:59 PM
You need to use more words. I have no idea what you are asking.
Old May 19, 2017 | 03:37 PM
Robert4's Avatar
Hi, It seems that the BCM is not working. I had some engine issues but I cured them and this thing is nuts at 20lbs of boost. But everything that is not on the ECM isn't working. There's power at the BCM that I can tell. Everything that the BCM controls does not function. When hooked up to a scanner you can manually operate a couple of things. It also won't recognize the keyless entry. Any test I can do to verify whats going on. I have access to a Snapon scanner to use. I hope I gave enough information. Thanks.
Old May 19, 2017 | 03:57 PM
Have you checked the BCM fuses on the underhood fuse box, #4, #6?
So, no auto headlights, dash lights, radio, power windows, stop lights power steering, interior lights, airbags, HVAC etc? If it will start then the PK3 is working.
What happened before the failure?
Old May 19, 2017 | 06:00 PM
Just a thought, how is your battery condition, these trucklets hate a dying or dead battery!!
They don't cotton to loose or dirty ground connections either.
https://www.chevyhhr.net/forums/how-...cations-56504/
2006corvette
Apr 7, 2015 06:05 PM
paulstanley19147
Jun 28, 2012 08:35 PM
aloppen
Nov 13, 2011 03:01 PM
BlackScreaminMachine
Jun 22, 2010 04:34 PM
Rotor
Jun 15, 2010 06:32 PM
