Bcm/LED
Old Aug 6, 2016 | 11:53 AM
Bkspring's Avatar
Thank you for that info. I put my original bcm back into my car. The only issues I'm having are the lift gate not working and the auto start. As soon as I get off work I will be checking the items you have suggested
Last edited by Oldblue; Aug 6, 2016 at 02:20 PM. Reason: Corrected spelling to make the read easier.
Old Aug 6, 2016 | 01:46 PM
Bkspring's Avatar
Donbrew,
First I would like to thank you so much for all your help, to be honest I didn't think I would get any answers, other than take it to your local dealer. So thank you. Now for my HHR, I put incandescent bulds back in. Took apart my fuse panel to find three of the four plugs lose enough to be taken off by hand. So i fixed them.
Put original bcm back in, and charged the battery. So original problems fixed. I still to get bulb for third brake light. And after all of the previous work my lift gate wasnt working as I mentioned in my last post. But I went out to my car and tried it again, and it opened so I don't know what was wrong earlier. You had asked me if I could get into tpms, I don't know how or what that is. But yes my door locks do work. But not my remote start, but I have yet to get the tail light fixed 100%. Is the tpms were you reset your oil change indicator?. And again I am so thankful for all your help.
Last edited by Oldblue; Aug 6, 2016 at 02:27 PM. Reason: Spelling and punctuation to make the read easier
Old Aug 6, 2016 | 02:19 PM
TPMS is the tire pressure monitor system
Old Aug 6, 2016 | 02:27 PM
Bkspring's Avatar
I dont have that system on my car
Old Aug 6, 2016 | 02:30 PM
Ok , so you just need the replace the burnt bulb in the third brake light and that should resolve your remote start and cruise control issues. Those are a 921 bulb there are 4
Old Aug 6, 2016 | 03:18 PM
Bkspring's Avatar
Well car is just about fixed,I replaced the tail light bulb ,now all lights working properly. The only thing wrong now is my remote start. I double lock my doors push the remote start and hold. And all I hear is click click and nothing. Anybody experience this?
Old Aug 6, 2016 | 04:07 PM
Look at page 2-9 in your Owner Manual for a list of things that will inhibit Remote Start.
Page 3-48 how to enable Remote Start.
Old Aug 6, 2016 | 06:17 PM
Yes and double check your tail lights and third brake light.
Also check to ensure your good is closed, properly
If you have a CEL , then the remote start won't work!
If there is no CEL then try a battery lobotomy, disconnect the ground wire at the battery for 30 minutes to reset the computers.
Old Aug 10, 2016 | 02:27 PM
Bkspring's Avatar
Remote start
Hello everyone,
I'm looking for some assistance on fuxing my rmote start. So before anyone askes: yes all my lights work properly my hood doors and lift gate r shut. And it is tured on.. so i lock the doors twice hold the remot start button. I hear. The fule pump turn on and three cliks under the hood. But no starting. Anyone have a suggestion?
Old Aug 10, 2016 | 03:05 PM
What has changed since it did work? Has it ever worked? Have you checked the hood ajar switch, it is part of the latch and a bit complicated electrically.
What year/model? Are you sure it is factory installed (AP3 on the glovebox sticker).
