Blower fan problems
Old Jan 11, 2023 | 01:47 PM
Gearhead1's Avatar
Blower fan problems
To start with the friendly dash slap would make mine go to work
Old Jan 17, 2023 | 08:19 AM
Gearhead1's Avatar
Originally Posted by Oldblue
Where do you bump it, by the glovebox or the HVAC switches panel?
on my 2011 when the fan dont work…..seems like the sweet spot for the “love tap” to get it going is from the bottom, right below center of glove box. So far been 100%. Any idea’s. Intermittent electrical problems are the worst!…lol
Old Jan 17, 2023 | 08:25 AM
Loose connections like the ground point, the relay connection, the blower motor, even the HVAC control module.
Old Jan 17, 2023 | 08:40 AM
Gearhead1's Avatar
Yeah,…..I was just wondering if there was a common gremlin. Guess I will remove the insulating cover so I can check the current paths next time its not working
Old Jan 17, 2023 | 08:55 AM
You can make sure all the fuses and relays are firmly seated in both fuse panels, and make sure the under hood fuse block halves are tight, the 5 bolts are 7mm
Old Jan 17, 2023 | 08:57 AM
Gearhead1's Avatar
I will check the fuse box halves….havent done that
Old Jan 17, 2023 | 08:59 AM
Continuity not current.
Old Jan 18, 2023 | 08:06 AM
Gearhead1's Avatar
I mean current path…then I can check continuity
Old Jan 18, 2023 | 08:44 AM
Lonwane's Avatar
My experience with electric motors is that if they need a 'kickstart' the bearings are going or gone.
Replacing the motor is not as difficult as it seems.
Takes about an hour of cutting out and instakllng new one.
For me the hardest part was remembering to empty the glovebox before removing it.
Old Jan 18, 2023 | 10:01 AM
We are assuming that you have taken the filter out and looked for something blocking the fan blades. Lots of reports of 15 year old filters falling into the fan.
"Stopped working on high" pretty much narrows it down to the switch, since high bypasses the resistors.
