blower fan works, but no forced air from vents
Old Feb 12, 2009 | 08:43 AM
wrusprod's Avatar
hey folks. I have a 2006 HHR. lastnight we had a lot of rain and Im sure its related to it.
My blower fan turns on, all speeds. sounds fine. but nothing is coming out of the vents. I tried all settings of vents but nothing. any ideas??
Old Feb 12, 2009 | 08:49 AM
pitbull76's Avatar
Possibly water's leaked in and clogged the cabin filter. If so, fix the butyl patch area. to fix the leak and replace the filter.
Old Feb 12, 2009 | 10:21 AM
ZTony8's Avatar
Seems like it could be the mode cam or the air inlet actuator.They're located on the heater module.
Old Feb 12, 2009 | 10:51 AM
wrusprod's Avatar
now, it wont start. turn the key and accessories come on,but doesnt turn over. I can use the factory remote start. it starts the car. I put the key in and turn "on", the engine shuts off. did that a couple times, now that doesnt work.
we had alot of rain/wind lastnight. the floor is wet under the blower assy. fuse box is dry.
Im at the Dealers now. keep the suggestions coming and I will give the solution...hopefully soon!
Old Feb 12, 2009 | 04:49 PM
wrusprod's Avatar
Pitbull76 was correct on the cabin filter. The not starting was a problem with the Keys security. It had to be relearned...
Dont know why two different things had to happen together!.Luck I guess.
Thanks for the help! hopefully this will help out someone in the future.
Old Feb 13, 2009 | 07:15 AM
esmarkey's Avatar
Thanks for the update, it's good to get final resolutions for our knowledge base.
padlockbob
Jun 4, 2015 03:01 PM
frank kaminski
Sep 7, 2014 08:53 AM
SSocal
May 28, 2013 09:24 PM
Cokeybill
Dec 8, 2008 08:46 PM
fast98ws6
2.2L Performance Tech
Apr 9, 2007 04:28 PM
