blower motor stops and starts intermittently
Old Mar 17, 2014 | 09:57 AM
edjew1's Avatar
the past few months my blower for the heater will be fine for days, then it will shut down sometimes for a few seconds, sometimes for a whole day??? any suggestions will be appreciated...
Old Mar 17, 2014 | 11:08 AM
Welcome to the site.
Probably gonna be the resistor or the fan motor itself. Hard to say. When it shuts down, try turning it to the Hi setting. If it will come back on, the resistor is most likely going bad.
Another thing to check is to make sure the fuses and relays are fully seated in the fuse boxes. Some HHR's fuses and relays have been known to "wiggle" loose over time and cause issues.
You can also use the Search function on this site. There are several threads devoted to fan motor problems and fixes.
Old Mar 17, 2014 | 03:13 PM
Recently there have been a few problems posted that turned out to be faulty cabin air filters. More like overused, abused, never knew there was one problems. Changing it is in the Owner Manual.
Old Mar 18, 2014 | 06:24 PM
Hey there,
I'm sorry to hear of this concern that you are having with your vehicle. I am not properly trained to offer technical advice, but I will be glad to look into this for you. If any extra assistance is needed please feel free to reach out to us via PM. In the message please include your VIN, current mileage, preferred dealership, and full contact information. We look forward to hear from you!
Kristen A.
Chevrolet Customer Care
Old Mar 18, 2014 | 06:54 PM
to the forum!
Good advice in posts #2 & #3.
Old Sep 10, 2014 | 09:45 AM
RoadKill1948's Avatar
I'm having the very same problem. Was your problem resolved?
Old Sep 10, 2014 | 09:53 AM
the op just had 1 post so, unless they post a reply we will most likely never know if their issue was ever resolved.
Old Sep 10, 2014 | 12:00 PM
oldracer's Avatar
My wife's 2003 Caddy had this issue and since it was right behind the glove box I would wack it with a rubber mallet. I got tired of this and finally dropped the fan assembly out of the car and that was very easy. I pulled the cover off the motor and it was packed with dirt and goop as was the fan blade section. I used a whole can of electrical cleaner getting things clean and it works great now.
If you check the fuses and they are fine then a good inspection and cleaning is probably necessary?
Old Sep 10, 2014 | 08:26 PM
Kookie's Avatar
I've gone through 2 replaced blowers & resistors. 1st was because of the leak under the front cowling. Replaced it with an aftermarket blower that sounded like a jet engine. Hated that crappy blower. It also finally died because of a bad connection. You could kick it and it would turn on. Upon pulling the blower, the connector plug was fried. It was quite melted. It cost me a few bucks but they had the plug on hand at a NAPA store. I spliced the new plug in with soldered butt connectors and heat shrink. Found the resistor blown too with the new motor. Replaced that and its been going good for about two years. The second motor is a bit quieter, but still loud on high. BTW, this is a 2006 LT.
Old Dec 1, 2014 | 11:40 AM
I had seen several references to the butyl
patch leaking, but it doesn't look like mine 2011 ever had the butyl patch
