Brake adjusters
Old Mar 20, 2013 | 08:19 PM
jduffin's Avatar
Brake adjusters
I have a 2006 hhr, I've replaced the rear brake shoes twice, drums once, checked to make sure the adjusters are free. Still, the auto adjusters don't seem to be effective. Any ideas as to how to correct this problem?
Old Mar 20, 2013 | 10:30 PM
Manually adjust the rear brakes when you change your oil, or every 5,000 miles. The "self adjusters" don't work worth a hill of beans, its a known HHR quirk.
Old Mar 21, 2013 | 09:01 AM
solman98's Avatar
Ain't that the truth.
Old Mar 22, 2013 | 02:22 PM
jduffin's Avatar
And here I thought that it was just me..Crappy rear brake adjuster setup...
Old Mar 22, 2013 | 03:39 PM
What it takes to make them work: Back up at 10-15 MPH down a hill then slam on the pedal to attempt a lock up. Do that several times, it helps if you load a few sand bags at the very back of the cargo area.
The problem is there is not enough weight transfer to the rear to get the leading shoe of the rear brakes engaged before the front brakes stop the car. The leading shoe has to rotate counter-clockwise in order to make the adjuster lever move the star wheel.
Old Mar 22, 2013 | 03:43 PM
I do the every oil change , inspect and adjust rear brakes, works for me
Rjj
Oct 22, 2017 08:56 AM
REDHHRSS
Jul 20, 2012 05:45 PM
Doctuh
Oct 27, 2010 03:29 AM
09_SS
Sep 30, 2009 10:25 PM
05gt
Jun 10, 2008 10:46 PM
