Brake judder again
Old Nov 27, 2016 | 09:50 AM
LT and LS rotors are the same size.
It's the SS rotors non Brembo that are larger.
Your right about the undersized that why I posted Solman98's thread, in post number 4
Old Nov 27, 2016 | 11:17 AM
Originally Posted by slonny
I would have never thought it is the case, but it seems like my brake pads are worn down almost to bare metal! I just replaced those 6,5K miles ago with ACDelco 14D1160CH Advantage Ceramic Front Disc Brake Pad Set.
But you said the rear brakes are "fine". Rear brakes not doing their job is the ONLY reason for all 4 of the pads to wear out prematurely.
BTW, the break in procedure is NOT a full stop from speed; if you come to a full stop with hot brakes deposits will occur.
Proper way is to ALMOST stop, come to complete stop after cool down.
Look at your rotors after a panic stop; you will surely see the outline of your pads.
I am of the no resurface school. The only time I do anything is when I want to save a couple of dollars and have a coupon for rotor turning at PepBoys. But I never let the rotors get too groovey.
TN Dewstiller
Mar 23, 2015 07:18 PM
working on it
Mar 15, 2015 12:28 PM
donbrew
Maintenance and Upkeep
21
Sep 25, 2013 09:41 AM
dustin6119
Aug 18, 2012 10:35 PM
GRUnderwood
Jan 31, 2011 10:29 PM
