Chevy HHR Network
-   -   Broken Rear Spring (https://www.chevyhhr.net/forums/problems-service-repairs-42/broken-rear-spring-58583/)
dano40 Mar 17, 2017 04:21 PM
Broken Rear Spring
1 Attachment(s)
Right rear was clunking. When I finally got under to look I saw a broken spring. Anyone else had this happen? Mines an 08 with 115k. Any brand recommendations? I was thinking Moog
Oldblue Mar 17, 2017 04:25 PM
Stock height, Moog!
Lowered to level you tail end! Canuck Motorsports
https://www.carid.com/moog/rear-coil...n-cc81065.html
X2 plus shipping or
https://www.chevyhhr.net/forums/clas...dropped-58350/
One price, includes shipping!
donbrew Mar 17, 2017 04:59 PM
one other I have heard of. https://www.chevyhhr.net/forums/gene...springs-41167/
You should probably consider new jounces and isolators (the top & bottom seats).
dano40 Mar 17, 2017 05:30 PM
Thanks for the quick responses. I'll look at parts tonight including shocks (there original).
denny Mar 22, 2017 07:51 PM
Both of my springs broke
Just replaced both of my broken springs ,shocks, struts and sway bar links last night with my mechanic friend Jon's expertise. 96,600 miles at this time, will get an alignment tomorrow and we should be good for awhile.
donbrew Mar 22, 2017 08:02 PM
Why an alignment? Nothing you replaced affects the toe.
Oldblue Mar 22, 2017 08:25 PM
Spring is here ! Enjoy the ride
aradmahogany Mar 22, 2017 08:52 PM
X2. I replaced damn near the entire guts of the wheel well and never needed an alignment.
dano40 Mar 27, 2017 09:40 AM
$82 for springs & shocks (Moog & Gabriel Ultra) from Rock. I ended up using a spring compressor because my rubber brake lines seemed to be stretched to the max and there still was not enough clearance. Only video I could find was for a Cobalt that seemed to have a different brake line setup, allowing for more pivot of the lower arm?
donbrew Mar 27, 2017 09:47 AM
I used a prybar to get the extra bit. I didn't have a problem with brake lines.
