A/C blower won't shut off car stalls
Old Jul 22, 2024 | 03:45 PM
mallorysadie's Avatar
Did you follow the diagnostic instructions in the links?
My son is working on it now will post update when he is done
Old Jul 25, 2024 | 12:14 AM
Yes all was good. He did a fuel pressure test it was 42 I'm not sure what that should be.
Old Jul 25, 2024 | 06:10 AM
It should be 55 to 60 psi
Old Jul 25, 2024 | 04:07 PM
I'm getting a fuel pump today hopefully it will fix the issue. I'll let you know when I get done working on it.
Old Jul 30, 2024 | 09:06 PM
New pump installed it still surging as though it's running out of gas
Old Jul 30, 2024 | 09:25 PM
Are the p0106 and p0107 "current " codes? Or are they "historic" or "stored" codes? Or maybe they are "pending "?
Old Jul 30, 2024 | 11:44 PM
​​​​p0107 is now pending. After doing all that work and spending $500 I still had the surging but I changed out O2 sensor before cat and the car is running like new just the pending P0107
Old Jul 31, 2024 | 07:09 AM
Check the MAP sensor wires, the connection might be loose or disconnected
Old Aug 2, 2024 | 04:57 AM
My son just found a broken prong in the MAP sensor I will replace it tommorow I sure hope this fixes my problems. We did find crumbling wires to the O2 sensor before the cat replaced the connector but the issue with P0107 never went away. I will update after replacement of MAP.
Old Aug 3, 2024 | 04:20 PM
I have a 2010 Chevy HHR Lt AC blower will not shut off when I turn it to the off position car keeps stalling please help
UPDATE. The switch for heater/AC was burnt so got a new one. But the car keeps throwing P0107-P0106 I've replaced both MAF & MAP Sensors but the codes come back if I put my car in reverse I'm a 62 year old and I'm not sure what to check next I can't put it in the shop I live on a fixed income in California.
When I first posted this the one thing I forgot to put on here was my traction control needs servicing and the ESC is off I'm at the end of my ropes now this car is driving me crazy it ran good when I changed the O2 sensor the next day it wouldn't run at all I don't know what else to do I've done a spent over $750 and still can't find the problem if anybody can help me please tell me something I'm alone down this now I have no help the only readings were good on the map sensor so I don't know what it could be
