A/C blower won't shut off car stalls
Old Aug 3, 2024 | 06:08 PM
The traction and ESC lights will go out after the issue is resolved.
Old Aug 3, 2024 | 06:11 PM
You said the MAP sensor had a broken pin? You might have a look at the other half of the connection, see if something there caused it to break.
Old Aug 10, 2024 | 05:04 PM
mallorysadie's Avatar
Originally Posted by donbrew
Has any body done any work around the dash board?
What happened just before this started?
Yes about 3 months ago my stock radio would work all the time so took it in and new stero was installed it works ok
Old Aug 10, 2024 | 09:38 PM
The blower switch or wires could have been damaged. Or, whoever did the wiring didn't know what they were doing.
Old Aug 10, 2024 | 10:00 PM
I thought the blower issue was fixed?
Old Aug 11, 2024 | 06:48 PM
  #26
I'm not sure if I'm posting right, but the blower is fixed I changed the controls. My son said there was a 5 volt reference at the MAP but after checking with a new multi- meter the signal is only 2.3 I'm trying to do what you said in earlier post but I don't have a book on this car or any wire diagrams so it will take me some time to check the wires down to PCM. Is this car worth keeping it only has 140,000 on it.
Old Aug 11, 2024 | 08:56 PM
  #27
It's worth keeping. In donbrew's signature, there is a link to shop repair manuals downloads, including wiring diagrams. If you can't see his signature, then you're on the mobile site, you'll need to get to the "full site ".
Old Aug 17, 2024 | 01:46 PM
  #28
Thank you. Have you heard that you have to program new fuel injectors? Just curious that what someone told me but I'm not sure.
Old Aug 17, 2024 | 01:50 PM
  #29
I’ve changed many fuel injectors, never had to program them.
Old Aug 17, 2024 | 02:42 PM
  #30
Thank you. Just wondering if that is why I have p0171 I do know now there is no low fuel trim it is at 0%
