A/C Compressor Won't Kick In
Old Jun 12, 2019 | 02:46 PM
HHRjim's Avatar
A/c crompressor clutch won't engage
SS350
Checked the HVAC related fuses and relays in the console fuse box and all we're good. All the wiring harness that I could see looked good.
Pulled the compressor clutch relay in the under the hood fuse box and tried jumping across the compressor clutch load and line terminals without success. I did have battery voltage at those terminals.
Old Jun 12, 2019 | 04:02 PM
See post #10, the 2 inputs are the engine temp and the pressure switch.
Old Jun 13, 2019 | 09:40 AM
HHRjim's Avatar
I disconnected the wire harness to the a/c compressor clutch and had battery voltage at the connector with the A/C button on the dash "on" and did not have battery voltage with the A/C button on the dash "off'".
This test indicated to me that the A/C compressor iclutch is not working.
There doesn't seem to be a way for the diy'er to change the a/c clutch. I can hardly see it let access it.
Any thoughts on what to do?
Old Jun 13, 2019 | 11:08 AM
Get a new compressor.
Old Jun 13, 2019 | 11:28 AM
Cat Man HHR's Avatar
You will have to remove the compressor. There was a person who changed out his engine and said he unbolded the compressor and left the lines on it.
If this can be done it doesn't look like a bad job to just change the clutch. A few bolts and some snap rings. The part is expensive but less than a compressor from Rock Auto.
Here is a picture of the clutch parts:
Old Jun 13, 2019 | 01:35 PM
You may want to check the grounding side of the compressor plug. Would hate to see you buy a compressor or clutch, then find out it was just a bad wire connection.
Old Jun 13, 2019 | 03:10 PM
Who would do that?
See my ads on Craigslist for Garage door opener and garbage disposer.
Old Jul 20, 2019 | 12:55 PM
HHRjim's Avatar
2011 HHR a/c compressor clutch
I ordered a new clutch from Rock Auto. Parts.
Changed out the old clutch with from underneath and the right wheel well.
Unbolted the a/c compressor from the engine block without disconnecting the a/c hoses to gain enough room to remove the clutch. The hardest part was removing the 1.5 inch snap ring that held the coil to the compressor body. It's in a1.5 inches deep cylinder and very hard to reach with the compressor partly installed. I made extra long points for my snap ring pliers using 3/32 long handle Allen wrenches.
Took about 6 hours but all works good now. Just in time for the heat wave.
Old Jul 21, 2019 | 12:06 PM
Good for you !
Glad to see you can think outside the box.
Sorry the job took that long.
Old Jul 21, 2019 | 08:27 PM
HHRjim's Avatar
Thanks catman for all your advice.
