A/C Problem
Old Jan 23, 2019 | 04:03 PM
mbrooks's Avatar
A/C Problem
Outside temperature was 101 turned on A/C to Max Cold and only hot air blew out. Turned temperature control dial down one
position and started blowing cold and then started blowing hot what is the issue.
Old Jan 23, 2019 | 04:07 PM
Welcome to the site, I’m gonna say the blend door actuator is broken, do you hear a clicking noise? Above the glove box area?
Old Jan 23, 2019 | 08:40 PM
Welcome....
Old Jan 24, 2019 | 08:27 AM
The issue seems to be that you don't understand the temperature control knob. All the way counter clockwise (blue) is cold; some people (my wife) think straight up is normal position.
You can get a free digital Owner Manual via the link in my sig.
Old Jan 24, 2019 | 11:23 AM
Cat Man HHR's Avatar
How long have you owned the car?
Year, model and mileage.
Thanks
Old Jan 24, 2019 | 06:11 PM
Wait a minute...........OP says the outside temp was 101 ???
Guessing this isn't a recent problem with his AC. I'll hold my thoughts until he returns with some more details.
Old Feb 2, 2019 | 03:27 PM
rhomanski's Avatar
I just replaced the control panel on mine for a similar problem. Below 85F the AC/heat worked perfect above 85F it would blow hot air when turned full cold and AC would not come on. If I turned up the knob 3 positions it would blow air at almost ambient temperature. I got the control panel from Ebay for $35 and put it in the dash. All is right with the world once again.
urbexHHR
Nov 3, 2010 07:00 AM
06gray2ltHHR
2.4L Performance Tech
Aug 1, 2009 10:45 PM
ts5p
Oct 6, 2008 02:47 PM
Black Rose
Dec 7, 2007 11:28 AM
SIHHR
Oct 23, 2005 12:10 PM
