a/c problems
Old Jun 3, 2013 | 12:26 AM
luvmyhhr2011's Avatar
a/c problems
A/C air flow works sometimes and sometime not what could be the problem seems to turn on when I go over rail road tracks or bumps any ideas where the problem could be coming from use to work fine when I first bought the car it has just started to stop working . Thanks for any help.
HHR 2011 LT.
Old Jun 3, 2013 | 05:56 AM
Being that it's a 2011, do you have the bumper to bumper warranty left? If so, let the dealer take a look.
If you want to fix it yourself, sounds like maybe a loose wire connection.
If the blower is actually stopping and not just changing vents(diverting to defrost or heater vents) then you'll just have to trace it down.
I would start with checking the fuses, then the fan switch on the waterfall. They're easiest to get to.
Old Jun 5, 2013 | 07:41 PM
HHR 2011 LT.
Sorry that you are experiencing this issue with your vehicle. I can look into this problem for you if you private message me your name, address, vehicle identification number, and current mileage.
Thanks,
Jessica L.
Chevrolet Customer Care
Old Jun 8, 2013 | 10:13 PM
re: my post.
Thanks to the 2 reply's I will private message you with the information when your online thanks again to the responses.
Dharkons
Nov 29, 2017 04:42 AM
06chevyHHR
Jan 22, 2013 05:55 AM
SmootHHR
May 22, 2011 04:38 PM
HHR4JK
Apr 9, 2010 06:48 AM
SPPD
Jul 16, 2008 01:22 PM
