Caliper pin replacement
Old Jan 29, 2020 | 04:04 PM
slonny's Avatar
One of the pins on the front caliper is constantly sticking. I decided to replace both. Do I need to remove the rubber piece from the old one and move it to the new one. It seems that all of the caliper sliding puns come without that rubber component.
I got these from AutoZone https://m.autozone.com/brakes-and-traction-control/brake-caliper-bolt-guide-pin-kit/duralast-brake-caliper-bolt-guide-pin-h15064/350601_402112_4222?spps.s=5472&cmpid=LIA:US:EN:AD: NL:1000000:HRD:71700000060668104&gclsrc=aw.ds&&gcl id=CjwKCAiA98TxBRBtEiwAVRLqu_XtU6WULimo4KfWRDWH5Bz KghM16Yg6EnrUORRxxc9-h77vRMQ1UxoCUJgQAvD_BwE
Old Jan 29, 2020 | 04:06 PM
The new ones should have the rubber on the two pins . Or do you mean the rubber bellows?
Some kits show including the rubber pin sleeve and the bellows
Some don’t
Old Jan 29, 2020 | 04:17 PM
The rubber bits are grease seals, if they are damaged replace them.
Old Jan 29, 2020 | 04:57 PM
slonny's Avatar
I meant rubber sleaves that go on the pin ends, but it seems that I need to buy another kit for that. If pins and boots cost me $25, then I may as well get a refurbished caliper for $40.
https://m.autozone.com/brakes-and-tr...7_0_23467?aqs=
Old Jan 29, 2020 | 06:12 PM
You do know there are boot kits at RockAuto and we get a discount? Under $6.00
https://www.rockauto.com/en/catalog/...boot+kit,11515
Old Jan 29, 2020 | 06:38 PM
slonny's Avatar
Yes, it seems like I will be able to get the pins and boot kit for around $10. Never heard that members of The forum get discounts. How is that done?
Old Jan 29, 2020 | 06:52 PM
The details are in here, copy and paste into the order where they ask how did you hear of us.
https://www.chevyhhr.net/forums/supp...-2020-a-61707/
Old Jan 29, 2020 | 11:17 PM
slonny's Avatar
Thanks, Oldblue!
Just found out what my problem was. Up to this day, I was using synthetic brake grease to lubricate sliding pins. Didn't even know that it causes rubber to swell up. Just ordered silicone paste for that purpose.
MichiganMarty
Maintenance and Upkeep
19
Jan 27, 2021 06:59 AM
keyman4
Nov 2, 2018 06:03 PM
aradmahogany
Mar 6, 2018 06:56 AM
hurst2001
Apr 3, 2015 05:04 AM
carsrmilife
Aug 14, 2014 03:11 PM
