Cam Actuator Fail
Old Mar 21, 2017 | 11:14 AM
Ed Chrysler's Avatar
Angry Cam Actuator Fail
Looks like the 2.4 has the same probles the 6 has with cam actuator fail ... reults in motor not starting without warning and motor replace or scrap car ... no other options i'm told by the dealer.
Old Mar 21, 2017 | 11:20 AM
Welcome to the site, your dealership isn't identifying the correct issue or you had a CEL and they just described it vaguely to you.
https://www.chevyhhr.net/forums/how-...13-14-a-28779/
It's a very easy job with minimal tools!
Old Mar 21, 2017 | 11:45 AM
aradmahogany's Avatar
Yes Oldblue. Now, whoever you talked to might be telling the truth , or they may be really trying to screw you over. I would think the latter. I would ask for actual trouble code numbers and post here again. Nearly every member here has performed that repair. Easy peasy. BUT, I do believe that if the actuators truly fail MECHANICALLY they can cause some serious issues, but that is a very rare occurrence.
Old Mar 21, 2017 | 11:55 AM
Hi Ed, to the forums!!
I cannot recall anyone with the P0010/11/13/14(camshaft actuator) code(s) having a problem starting the vehicle. Please post up the actual codes here(not the descriptions, which can be misleading). We'll see if we can get you a proper diagnosis!!
Old Mar 21, 2017 | 12:53 PM
This has nothing to do with recall campaigns, so I moved it.
It also has no information in it. What is supplied is erroneous B.S..
I suspect "dealer" in this case means the used car dealer that sold the car, NOT a GM Service Department.
I have not heard on this forum any discussion about failed "cam actuator" causing engine damage.
If the OP comes back perhaps he can supply a few more words.
Old Mar 22, 2017 | 11:08 AM
spacer's Avatar
Looking at the username of the one-post-wonder... hmm....
Old Mar 22, 2017 | 04:12 PM
And Mr. C hasn't been back!
T's HHR
Jun 22, 2011 09:16 PM
Malfun10n
Oct 6, 2009 03:04 PM
RoSSpert
Aug 27, 2009 03:57 PM
SandyBeach
Dec 29, 2008 07:24 PM
Kennys2009HHR
Aug 2, 2008 10:06 AM
