Cam angle sensor
Jenny, your noise sounds like a failing wheel bearing, or possibly a damaged tire. It is unrelated to your P0011 code; just a fluke that they happened at the same time. Definitely tell the dealer about it while you're there. A failing wheel bearing will make noise that increases as your speed increases.
Jennybeeb,
Let us know how it goes at the dealership! I agree with pitbull76, mention this noise you are hearing to your dealer so they can check it out! Thank you.
Evan, Chevrolet Customer Service
You were 100% correct!
Took it to the dealer, and they installed the new intake cam solenoid, along with a right front hub bearing
I didn't think it was the bearing simply because I thought it would have been making more noise on the outside of the vehicle while I was driving if that makes sense...But nonetheless, they replaced it and my car is great again
