Cam angle sensor
Old Dec 20, 2011 | 06:46 AM
pitbull76's Avatar
Jenny, your noise sounds like a failing wheel bearing, or possibly a damaged tire. It is unrelated to your P0011 code; just a fluke that they happened at the same time. Definitely tell the dealer about it while you're there. A failing wheel bearing will make noise that increases as your speed increases.
Old Dec 20, 2011 | 03:15 PM
Jennybeeb,
Let us know how it goes at the dealership! I agree with pitbull76, mention this noise you are hearing to your dealer so they can check it out! Thank you.
Evan, Chevrolet Customer Service
Old Dec 21, 2011 | 03:46 AM
CeliaFoote's Avatar
Pitbull,
You were 100% correct!
Took it to the dealer, and they installed the new intake cam solenoid, along with a right front hub bearing
I didn't think it was the bearing simply because I thought it would have been making more noise on the outside of the vehicle while I was driving if that makes sense...But nonetheless, they replaced it and my car is great again
jlh152
2.4L Performance Tech
Feb 15, 2014 09:03 PM
techno ed
Aug 13, 2012 06:36 PM
twistrman
Jul 17, 2010 09:29 PM
ioweejun
Aug 29, 2009 01:04 PM
galladanb
May 2, 2006 08:40 AM
