Cam Chain Jumped Time
Old Apr 2, 2013 | 01:34 PM
07azhhr's Avatar
Originally Posted by Mr. Wilson
Okay, we picked up the Daughter's HHR this morning. Complete with a replacement used engine (and clutch - seemed prudent).
Question, at 68,000 miles on this (new) used engine, what is the likelyhood of this cam chain problem happening again?
Since it is not a typical wear issue like a timing belt would be it is hard to say if the new to her used engine will also have this issue.
Old Apr 25, 2016 | 09:49 AM
egadgetguy's Avatar
I am in the process of replacing my timing chain. Since the car already has the new stye tensioner, I am going to reuse it. I found out it is fairly easy to reset it. Here's how:
1. remove the c clamp.
2. pull out the inner piston
3. While holding the fat part of the piston with one hand, use a #2 flat screwdriver to turn the back portion [there will be an obvious place to fit the driver] clockwise. The piston will lock in at the extreme turn point.
4. reassemble [be careful not to re-activate it]
Done. no special tools needed.
Jcdew67
Jun 12, 2015 12:53 PM
davidhhr06
Jun 24, 2014 05:18 AM
manuelmenogga
Jul 8, 2013 01:14 AM
Dellidog
Feb 23, 2012 11:48 AM
Navyflyer11
Aug 12, 2007 12:38 AM
