camshaft position sensor
Buna-N/nitrile is a typical heat and oil resistant material. Another is Viton/FKM. Another is FLM. Most in stores will probably be Buna-N.
Advantages and Applications of High-Temperature O-Rings (manuf-rubber.com)
Camshaft sensors are dirt cheap new but tens of thousands of HHR owners have perfectly good used ones lying around because they pointlessly replaced them when it was a solenoid that was the problem.
Hello this is my first time here. I only recently ran into this website because i have been having issues with my HHR giving me a fault code for the camshaft position sensor. I have been been doing my due diligence to try and find the location for the sensor but have came up empty handed. I have seen the schematic for it being on the top right corner of the engine next to the fuel injectors but there is nothing there. I do see a spot for a screw to drive in and an opening but its not even remotely the right size for it to go in. I even went as far as taking off the starter in hopes that the sensor would be next to the crankshaft sensor but to no avail. I could really use some help with this problem and hope that someone does see this. My HHR is a 2006 with the 2.2L ecotec engine variant.
