Canadian powertrain warranty question
Old Oct 5, 2011 | 01:54 PM
saturnsw2's Avatar
hi all
this started about 3 weeks ago with a PO300 code that would set the cel randomly.
the light came on a couple more times in the past week but goes off after a couple starts.
today i decided to buy a code reader and it gave the following 2 codes:
PO303(cylinder missfire) and P1174(undefined) appeared.
after some searching it seems these are fuel injector related.with a tsb to replace all 4 injectors and do an ecm software update.
my question is:
are the fuel injectors covered under the canadian 2007 powertrain warranty.
i see on the stickys here that they are covered under the americam pt warranty.
thanks,jeff
Old Oct 5, 2011 | 02:54 PM
Snoopy's Avatar
Can't answer specifically because I'm from the U.S., BUT your Owners Manual and related paperwork that comes with the Manual should answer that question with some validity....other owners will probably only give their opinions.
You could also call a dealer and speak with the SERVICE MANAGER to see if it's covered.
Old Oct 5, 2011 | 03:51 PM
Tyler Harvey's Avatar
Powertrain is covered for the usual five years for all of North America.
Old Oct 6, 2011 | 06:27 PM
saturnsw2's Avatar
Unhappy
well were dropping the hhr off at the dealer for them to work on saturday,hopefully it will be under warranty.had another issue today ,the tc light came on and had a couple hard shifts.turned the car off a\nd it reset.
will have to get them to check the 2 solenoids on the top of the engine also.
will report back next week.
jeff
Old Oct 8, 2011 | 04:38 PM
saturnsw2's Avatar
hi all
got the hhr back this afternoon.
took 4 new injectors and a computer upgrade.
all fell under the powertrain warranty.
fuel consumption fell from 11.1L/100kms to 8.4L/100kms(mixed city/country)
got a spare key and it programmed while i was there also.
regards,jeff
FrugalAudio
Sep 1, 2014 04:45 PM
Lenny
Sep 19, 2011 11:22 PM
jonboyb
Nov 28, 2010 01:55 PM
GuitHHR
Jul 30, 2007 09:58 AM
