Does powertrain warranty include shift linkage?
My SS 5spd is stuck in second gear. Before I have it towed to the dealer, I'd like to be sure the shifter and linkage are covered under the powertrain warranty. Anyone know? Took a quick look through the manual and didn't see that kind of detail (maybe I missed it).
Try looking here.
https://www.chevyhhr.net/forums/prob...ge-list-22231/
Try looking here.
2010-current GM 5yr/100k Powertrain Warranty
Which seems to suggest that some items may have been added as of 2012 (retroactive to 2010). Either way, I don't see the shifter cables on either list (unless they're called something else). Disappointing.
Thanks, didn't see that in my search. But, it seems to date from 2009. I found this:
The info was supplied by ChevyMgr a former admin here who was at a dealership at that time.
As far as your problem. If you feel it's a cable issue, take off the shifter covers and have a look. There have been a few incidents where the shifter cable has been known to pop out of the bracket just in front of the shifter.
It may just be a case of popping it back in place and zip tying it down.
You could also try a Search. I know there was a thread a good while back that had some pictures of the cables and bracket.
edit: try this link.Post #3 has a good photo.
https://www.chevyhhr.net/forums/ss-s...85/#post488631
mclark
Aug 24, 2012 06:25 AM
