Can't unlock 2006 HHR with a dead battery
Old Oct 26, 2014 | 07:52 PM
  #31
hhr06NJ's Avatar
i saw a video on youtube, young Asian guy, no voice, just captions, use a string, like fishing line, tie a drop loop in the middle of about a 3ft length, work it in behind the upper rear door frame. goes right in, no damage; work the drop loop over the knob, pull tight against the knob and lift. try it. works easily, no bending, prying.
Old Oct 27, 2014 | 03:29 PM
  #32
MikeRuth's Avatar
I've done this using ordinary twine works like a charm! Amazing how easily and quickly you can get a door open using this method.
Old Oct 27, 2014 | 03:31 PM
  #33
MikeRuth's Avatar
Just to add, I have a 2006 and I can lock the doors using any option, FOB door switch or manual and have always been able to unlock the door using the key.
Be prepared to turn off the alarm.
I don't think it's right that if you have the correct key that you can not unlock the door for any reason.
Old Oct 27, 2014 | 05:07 PM
  #34
Grizzly old man's Avatar
I cut into the electric unlock wires inside the car and mounted a simple momentary contact switch in a secret location under my car because my wife likes to lock the car with the keys inside a lot.
I started doing this with my '76 Buick. It was the first car I ever owned with electric door locks and it was the first car she would routinely do this on.
Since then I have installed a secret push button on all my cars with electric door locks.
Of course this will not work if your battery is dead.
2008LT
Sep 17, 2014 05:28 PM
Zagohhr
Jan 25, 2012 07:46 PM
JJ_HHR
Mar 13, 2010 08:51 AM
longhornss
Feb 27, 2009 01:15 PM
