Car will not unlock at all with fobs or keys
Old Jan 2, 2015 | 06:38 PM
MidgetHurse-LT's Avatar
Are you still locked out? I have a problem right now that could also give you an idea/access! My door lock fuse (#26 on block at passenger's left leg) is blowing when try the door locks with either FOB or door switches. One thing that does work with FOB and door switches is the back hatch even with that fuse blown for the door locks. Try that with a FOB and check the hatch. That may at least get you inside and avoid a tow charge.... Then check fuse #26 and see if it is blown. There is a spare 15amp on the same block that you can swap out. Of course, if it blows again, you will be where I am with this problem. I had to put a 20amp in just to get the door locks unjammed. Now I am leaving the fuse out until I can figure out which door lock is blowing it. That is why I found this thread... Hope this helps! Please, let us know...
MarkInMLB
Jun 25, 2012 07:06 PM
tpaul
Sep 10, 2011 09:38 PM
Beachbum1
Apr 10, 2010 09:29 PM
GiggityGoo
Jan 26, 2009 05:52 PM
wxman
Jul 16, 2008 12:08 PM
