Cel, code P300, p301, tc off
Old Apr 18, 2024 | 07:25 PM
Do the compression test. You might have bad rings or valves, or a hole in the piston...
Old Apr 18, 2024 | 07:31 PM
The P03000/301 are causing the hard shifting and all of the other symptoms you cited. As soon as that is fixed all will return to nice. Most "performance" codes turn the traction control off and put the computer into open loop mode.
You need to do a compression test and look at the timing chain; ANY slack between the cam sprockets is bad.
Misfires are rarely spark related, unless you don't use ACDelco 41-103. A tune up is replacing the plugs at 100,000 miles and cleaning the throttle body and MAF.
Old Apr 19, 2024 | 12:43 AM
Stx78362's Avatar
MAF/ throttle body was the culprit
thank you for responding. I pulled the maf cleaned the contacts, pulled the throttle body it definitely needed a little cleaning. Cleared the codes. Plugged everything back in drove it 50 miles. Shifts smooth as butter, no more cel/ tc. It used to have a rough idle that is no longer apparent and I gained 8 mpg.
I’m hoping its a solid fix, I appreciate everyone’s suggestions and input.
Old Apr 19, 2024 | 06:09 AM
Thanks for your follow up and feedback.
Old Apr 19, 2024 | 07:58 AM
Codes clear themselves when fixed. When you clear them ALL of the OBD2 testing starts from scratch, some take 2 weeks to run.
Don't clear codes unless you know what you are doing, the CEL is not the problem it is the cause of the CEL that is the problem.
Old Apr 19, 2024 | 10:09 AM
PulpFriction's Avatar
Originally Posted by Oldblue
Caveat emptor , buyer be ware. I always bring my scan tool and ask permission to run the scan, if they decline, I walk away, If they are ok then the HHR is usually ok. Deserterat posted about his experience, it was the MAF sensor
Now yer making me feel guilty. I don't ask. I just slip the Bluetooth dongle in as I get behind the wheel. When I pull out my phone, they think I'm checking for messages.
But you raise a good point. Asking and getting a "no" might be a red flag. But it also might be that the owner is clueless and paranoid about hurting the car. New policy. Slip the dongle in and screenshot any codes. Remove dongle. Ask permission. In that order.
So much great advice here! EVERY SINGLE reply was accurate and useful. Same question at Farcebook, EVERY SINGLE reply might be useless or wrong. Best case, maybe 25% accurate.
Old Apr 19, 2024 | 11:06 AM
Or, gone off on "don't buy this buy that" and never get an answer to the question. Leaving people in the future with a waste of time search.
Felony
May 12, 2021 10:12 PM
afs9
South Pacific
28
Dec 15, 2008 10:27 AM
fixithud
Jul 11, 2008 12:06 AM
GDZHHR
Mid Central
22
Oct 28, 2006 11:15 PM
