CEL Purgatory
Old Mar 10, 2014 | 10:09 PM
HHRMom_0791's Avatar
Well we've officially moved out of purgatory to h***. Finally heard back from the service advisor and it sucks. After extensive testing with the smoke machine, they found a very small crack on a nipple for the gas tank. 😥 it's on top of the tank. The only solution offered is replacing the whole gas tank. The estimate to do that is around $1000. I'm hoping our extended warranty will cover it!
I did some quick looking and couldn't even find the tank for sale easily. Is this even feasible to consider as a driveway diy project? Can the tank possibly be repaired instead of replaced?
This seriously sucks!
Old Mar 10, 2014 | 10:37 PM
Lucky's Avatar
I have never tried repairing a plastic fuel tank but used ones should be readily available. My guess would be 100 to 200 dollar range. Here is a thread for replacing the fuel pump. It may help some.
https://www.chevyhhr.net/forums/how-tutorial-library-21/fuel-pump-replacement-36541/
Old Mar 10, 2014 | 10:58 PM
I also want to consider any other maintenance things that may be worth doing , like the fuel filter, etc. Not sure if there's anything else prone to failure that would be worth doing at the same time.
Old Mar 10, 2014 | 11:10 PM
Lucky's Avatar
Our car don't really have a fuel filter that it serviced like older cars. Ours uses a filter inside the tank on the fuel pump. A used tank should come with the fuel pump but who knows how many miles will be on it.
You could install a new pump with the used tank or transfer your pump to the replacement tank. It's depends on how much you want to spend.
Old Mar 11, 2014 | 02:03 PM
Get them to give you a PDF of the gas tank from the parts department showing what they are talking about then post it here so we can get an idea. Sounds kinda fishy to me.
Old Mar 11, 2014 | 02:18 PM
I concur with Donbrew, never heard of this issue, but anything is possible, and it should be covered under emissions warranty as it is part of the system.
Old Mar 11, 2014 | 02:22 PM
this is a shot of the tank I found some listed on E-bay from $35.00 to $200.00 plus shipping of coarse so which is the broken / cracked part?? and why added all up nowhere near $1000.00
Last edited by Oldblue; Mar 11, 2014 at 03:12 PM. Reason: just trying to make an image appear
Old Mar 11, 2014 | 02:23 PM
this is a shot of the fuel pump assembly, which hose nipple is cracked or broken?? and why a G to replace the fuel pump??
Old Mar 11, 2014 | 02:37 PM
RockAuto has the fuel pump listed from just under $300.00 for AC Delco full assembly including the fuel level sensor W/ internal strainer they do not list a fuel tank
Old Mar 11, 2014 | 03:08 PM
I am guessing they are talking about one of those hoses or yellow nipples they are connected to. I have no idea how to cause those to fail, except for somebody has previously had the tank out. How the heck could they get up there to see smoke?
