Central locking has a mind of it's own
Old Dec 20, 2019 | 10:52 AM
chade_10's Avatar
Hello! I have a 2006 HHR 2.4l. The central locking is working sometimes but not all the time with the remotes. If I press unlock once on the remotes it will eventually unlock the driver door. I need to unlock the rest from inside. It won't lock from the remotes. Sometimes if I press unlock on the remote a few times it will unlock several times minutes later. It will randomly unlock and lock while driving as well. This is the same with both remotes so I don't believe it's a remote problem. The batteries are both good. I tried disconnecting the cars battery for 30 minutes to see if it would reset anything but it didn't change anything. Does anyone know how I can try to fix this or is it something the dealership will need to do? Thank you!
Old Dec 20, 2019 | 11:09 AM
Welcome to the site, no need for a dealership any self respecting mechanic can lube the linkage with a squirt of spray lube.
this is also a sign of a feeble and failing car battery, have it load tested at any auto parts palace, they usually don’t charge for this service.
Old Dec 20, 2019 | 11:15 AM
x2, plus, take the remotes apart and clean the contacts inside. A few owners have had problems with the remotes making sporadic activation's without being touched, indicating a worn out keypad typically. The pads are easily replaceable.
Old Dec 20, 2019 | 11:49 AM
Match up how many push buttons you have and order a new case and keypad from our friends at RockAuto
https://www.rockauto.com/en/catalog/...y+remote,10433
and we even get a discount code
https://www.chevyhhr.net/forums/supp...-2020-a-61707/
Old Dec 20, 2019 | 12:04 PM
the_shmoo's Avatar
These also correct a lot of problems with the keypad buttons.
I have these in all my fobs. Never had a problem since.
Keylessfix - Home
Old Dec 20, 2019 | 01:57 PM
Cat Man HHR's Avatar
Originally Posted by chade_10
Hello! I have a 2006 HHR 2.4l. Does anyone know how I can try to fix this Thank you!
How old is the car battery ?
Old Dec 20, 2019 | 04:00 PM
chade_10's Avatar
Thanks everyone this is great! I've never changed the battery and have owned the car for 6 years so it sounds like this could be it. It does sound a little sluggish when I crank it over to be honest. I'll change the battery this weekend and see if that fixes the problem. Thanks again! I'll keep you posted! :)
Old Dec 20, 2019 | 04:24 PM
Get the correct battery for the HHR!
Old Dec 20, 2019 | 04:32 PM
chade_10's Avatar
oh good point! What battery should I get?
Old Dec 20, 2019 | 05:21 PM
chade_10's Avatar
ah nvmd! THere's loads of threads about batteries! :)
