the chassis number
Old Apr 30, 2009 | 10:26 AM
HHRome's Avatar
the chassis number
Hi Guys
I am in search of the chassis number of the car,what I found is under the front windscreen but I need to know if there is and where is located the so-called punched.
It should be imprinted in the structure of iron car, but not clear if this happens in the U.S, or just what happens in Europe.
I have dismantled much of the car but nothing.I don't find those damned numbers frame.
Please help me
Old Apr 30, 2009 | 04:09 PM
Sno White's Avatar
I can’t tell you where the frame is actually stamped with the VIN(Vehicle Identification Number). The number you see at the bottom left side of the windshield is indeed what the USA uses to identify a vehicle. You will find this number on stickers at various other places in the vehicle, like the drivers door edge and on just about every piece of removable sheet metal.
Old Apr 30, 2009 | 04:41 PM
HHRome's Avatar
[QUOTE=and on just about every piece of removable sheet metal.[/QUOTE]
Just some piece of sheet metal that I try with this number but i can not find; the rest is like showed by you kindly . In which pieces of sheet metal have to try?
In this cursed country where bureaucracy reigns supreme, if they do not have this VIN that passage the plate.
Usually in Europe all cars have this VIN as part of the metal structure but only here in Italy is absolutely required in without which I can not move; however if I try again and if there were, where I can look for you again?
Thanks again for helping me, I am 2 months I've purchased.....but soon I'm sure that send nice photos of my HHR.
Old Apr 30, 2009 | 05:06 PM
hyperv6's Avatar
The stickers he speaks of are on the inside of the body panels. Fenders, doors even the bumper covers. They are proof of what vehicle the parts belong to if it is stripped for parts.
The easiest to find is the hood.
I am unaware of any number stamped in the frame. The Vin on the windshield is what is used here and some older GM cars had it under the dash in a second tag like the Pontiac Fiero.
Old Apr 30, 2009 | 06:14 PM
Cajun's Avatar
I will contact my police buddies....they will know if / where the frame is stamped.
Cajun / Al
This info so far....
"In those instances when a vehicle has a die stamped VIN on the frame, inspect and record the VIN on the frame rather than the VIN on the plate. In addition, the VIN is die stamped into the frame under the rear seat."
More to come.......
Old May 1, 2009 | 04:27 AM
HHRome's Avatar
You guys are wonderful:t
humb:
Next monday my mechanic friend shall dismantles the car while finding me the solution, he believes that we can and we must find, though at first concerned with technical operators civilian vehicle (the law) we have not succeeded.
I embrace you, because you hold me the moral high!!!!
Old May 8, 2009 | 01:24 PM
HHRome's Avatar
It's with great personal pleasure to inform you all that I can finally drive my HHR in Italy.
After so much suffer through countless vicissitudes, we did. I withdraw the license plates on Monday and I will feel better as like one of you.
and thanks again for the suggestions that had been precious
oceangoer
Apr 19, 2015 10:16 PM
DBHHRLT
Dec 1, 2008 08:39 PM
szyhxc
Maintenance and Upkeep
Aug 16, 2008 12:05 PM
Lone Ranger
May 29, 2007 12:26 PM
