check engine light
Old Oct 19, 2014 | 01:54 PM
Getting the codes read is the power. Just get the code(s) read and post them here.
Old Oct 20, 2014 | 07:36 AM
chitownmike's Avatar
I am going today to get the codes read. One other new development my remote start isn't working now either.
Old Oct 20, 2014 | 08:30 AM
... which is a result of the CEL code error condition most likely.
Old Oct 20, 2014 | 09:36 AM
LawDog88's Avatar
^ Yes. If check engine light is on, the remote start will not work. Safety feature, just in case the CEL is for something possibly damaging to the car.
Old Oct 26, 2014 | 09:48 AM
Got the codes read, engine not getting up to proper temp. Thermostat stuck open,or temperature sensing unit is bad.
Old Oct 26, 2014 | 11:54 AM
I don't know why that would cause the "POWER STEERING" message. Also, should not affect the RS since it should clear itself at every cold start.
I think you need a new fiskerator solenoid.
Old Oct 26, 2014 | 12:05 PM
Replace the T-stat with the GM unit there are many reported failures of the after market type, then go from there
Old Oct 26, 2014 | 12:22 PM
chitownmike - when people here say 'post the the code", they mean exactly that - not a verbal description (which is what you posted). The reason being that the autoparts store will often give a verbal description which may be incorrect, resulting in one replacing incorrect parts.
In this case, the verbal description is likely good enough - if you use the SEARCH tool at the top of the page and look for thermostat, you will find info on how to further determine if in fact it is the offending part that needs replacement.
purple people eater
Sep 17, 2016 01:07 PM
flooprigger
Aug 4, 2013 08:58 AM
jmpnjoe86
Mar 10, 2013 06:13 PM
hhr856
Nov 14, 2011 12:26 PM
cruzzonn
Nov 9, 2011 08:33 AM
