Check Engine light on - no codes
Hi Guys,
Lately, I have some problemos with my check engine light ...
I've had a few times the code for small Evap leak, so I replaced the gas cap.
After replacing the gas cap, check engine light is on again ... checked for codes again and although check engine light is on, I have no codes - go figure
Any suggestions pls ???
My light the check engine came on, and I could not figure it out. While chasing everything down I found the passenger rear turn signal was burnt out. I replaced that and thought I would take it into the mechanic to find the gremlin. I started it up and the check engine light went off.
Hi Guys,
I wish my CEL would come on.....
Mine is running bad....but the CEL just will not come on. Dealer said they won't look at it anymore because they can't diagnose the problem if the CEL isn't coming on...
I took it in, they could not pull a code. After they tried it went off for about 15 minutes then came back on. Of course it will be on all winter, just when you really want to use the remote start. I am tired of wasting time on this problem.
purple people eater
Sep 17, 2016 01:07 PM
camaro98z28
Apr 13, 2010 10:32 PM
