Chevy hhr shut off and wont start!
Old Nov 25, 2018 | 12:11 PM
theblakeh's Avatar
By hand, clockwise with a wrench
Old Nov 25, 2018 | 12:21 PM
Not sure I understand what happens when you turn the crankshaft.
Has the ignition switch recall been done? https://www.chevyhhr.net/forums/gm-r...-status-50716/
Is there spark?
Is there fuel?
Any wires look odd?
Do the electrical accessories work?
Is the run relay is working? #51 underhood
fuse #45 & #19 & #26 & #42 underhood
Old Nov 25, 2018 | 12:24 PM
Is there spark?
Is there fuel?
Any wires look odd?
Well, it was turned the correct direction, and the chain loosened. Not sure what to make of that.
Old Nov 25, 2018 | 12:25 PM
theblakeh's Avatar
I have checked everything, getting air/fuel/spark, 54psi of fuel pressure, all recalls have been completed, all electricals work, no wires look odd, and all fuses are good
Old Nov 25, 2018 | 12:53 PM
Turning the crankshaft clockwise should tighten the chain. Turning it counter clockwise will loosen it enough to jump a tooth or 2. That is with an analog clock
That is because clockwise pulls the chain from the top and counter clockwise pushes it to the top because of the way the tensioners and guides work.
Old Nov 25, 2018 | 01:03 PM
Actually, the P0122 has to do with voltage to the Throttle position sensor. So, my next guess would be looking at the wire loom that goes past the EVAP purge valve.
Old Nov 25, 2018 | 05:49 PM
The chain should still be addressed, the front guide could be snapped
Old Apr 2, 2019 | 08:43 AM
theblakeh's Avatar
took the car to a local shop, said it had no compression, im just going to swap it out for a motor with less miles, already got my old motor out and took the timing cover off and all the plastic pieces fell out as soon as I removed it
Old Apr 2, 2019 | 11:10 AM
Confirmed, timing chain guides failed , do yourself a huge favour and put a new timing chain and balance shaft chain with an upper bolt for the front guide.
https://www.chevyhhr.net/forums/how-...in-kits-60394/
Dorman has a version of this , which Mike from the Cobalt site made , his kit included 2 ARP guide bolts, one for the bottom of the front guide and one for the bottom of the rear tensioner guide.
Old Apr 2, 2019 | 11:20 AM
You mean to install the new parts on the replacement engine, right? If the valves on the original engine weren't already bent, the compression test may have bent them.
