Climate control blower switch operation
Old Sep 22, 2022 | 07:19 PM
greg8453's Avatar
Your head unit is bad.
Old Sep 22, 2022 | 07:50 PM
cmallory101213's Avatar
So what's the head unit and how do I get to it?
Old Sep 22, 2022 | 07:58 PM
Something is not connected correctly. Or the ground wires are loose.
by control switch do you mean you replaced the hvac panel?
Old Sep 22, 2022 | 08:09 PM
yes the switch panel in the dash. Whole new unit.
Old Sep 22, 2022 | 10:21 PM
greg8453's Avatar
If you have a good scan tool you can see what it's doing. I assume you made sure the unit has good power and ground.
I really need to quite assuming things.
Old Sep 22, 2022 | 10:37 PM
is there power to the motor?
is there continuity between the motor and the switch and resistor pack?
is there continuity between the resitor pack and ground?
does the AC compressor turn on when the switch is turned with the AC button on?
There is a splice in the orange wire near the motor that has been known to fail.
I don't know how a professional (expensive) scantool could possibly help. The only connection to the BCM is the "blower on" signal. I also don't know what the headunit might have to do with the blower
Old Sep 23, 2022 | 05:23 AM
A head unit or HU is the radio, nothing to do with the HVAC control panel.
Old Sep 23, 2022 | 07:23 AM
greg8453's Avatar
We tend to call the module the head unit regardless of the modules function. The head in this case is the HVAC module.
Old Sep 23, 2022 | 09:37 AM
Tomato Tomatoe, I don’t Donbrew doesn’t, RJ doesn’t, just trying to keep any confusion down.
Old Jan 11, 2023 | 05:53 PM
Gearhead1's Avatar
Blower fan ground …
….Im wondering if ground path (wiring) is bad between your fan speed resistor and switch….or ground beyond the switch
