Clunking issue: Solved!
Old Aug 2, 2011 | 08:44 AM
  #81
Originally Posted by 08bowtie
i notice there are alot of 07's in this thread - is this particular to 07??
my 08 has no front end issues with 56K
My '07 only has the "cold weather clunk" with 33k miles...... I can ignore it for several months out of the year.
@ chichi........... Not sure why the dealer would be throwing parts at it instead of finding the problem. With that many parts replaced they should start looking for something else as the cause.......
Old Aug 6, 2011 | 09:19 PM
  #82
diskullman's Avatar
I finally got my urethane sway bar bushings installed, and clunking is gone, feels like new again! No more clunks.
Old Sep 24, 2011 | 10:26 PM
  #83
alexrckid's Avatar
the (moog) endlinks are available in two different lengths(p/n K750012 9.86 center to center AND p/n K80252 11.80 center to center). anyonw know why the two different lengths and their applications..?? thanks.
Old Sep 24, 2011 | 10:28 PM
  #84
alexrckid's Avatar
and.....any info on the urethane sway bar mount bushings(manufacturers, part numbers..???). i dont have any problems(now) with my 2006 lt but want to be ready when the front end noises come around.....thanks, again.
Old Sep 25, 2011 | 01:27 PM
  #85
DaGrinch's Avatar
Check out this thread - https://www.chevyhhr.net/forums/maintenance-upkeep-50/replacing-sway-bar-links-36889/
Old Oct 1, 2011 | 07:15 PM
  #86
jdarter42's Avatar
2008 HHR LT clunking
I have read all the post about the clunking. My 2008 HHR LT has 54230 miles now. We bought it when it had 25000 miles and we only had it for about a month when the clunking noise started. I took it back to the dealer they replaced the steering column noise went away until 52000 miles. We are of course no longer under warranty the dealer said they would replace the column again if I would pay the labor.
We will try replacing the sway bar link and bushings before going back to the dealer. My car is never off the hard top or concrete roads.
Will update the progress.
2008 HHR LT, chrome package, leather, 25 mpg city, 32 mpg hwy.
2010 Ford F150 4 x 4
Old Oct 3, 2011 | 06:08 PM
  #87
jdarter42's Avatar
Well we replaced our sway bar links today. And that took all the noise out of my car. I would recommend anyone having the clunking in their HHR to change out the sway bar links. The ones that MOOG #K750012 make have the greasable joints much better than the factory set up. Bought the parts at Federated Auto parts both for $75 and that included VA tax.
Thank you to all those that made this topic for others to have help after the dealer gives up or you are out of warranty like me.
Thank you
Old Oct 3, 2011 | 07:39 PM
  #88
1970judge's Avatar
Good deal! Glad it worked for you!
Old Oct 8, 2011 | 08:32 PM
  #89
alexrckid's Avatar
well....in spite of not having any "clunking", decided anyway to go ahead and replace the sway bar links with what appears to be much better made MOOG K70012 pieces. ran into the problem where the ball turns while trying to release the nut(s).....but, found that there there are actually small 17mm flats on the backside that keep the ball from turning. used a 17mm open end......worked great. only thing is that the 17mm hex on the ball has rounded corners so the open end's gotta fit tightly........
Old Oct 10, 2011 | 11:01 PM
  #90
Ktmrider's Avatar
thanks for the information on this. This has been a sense of frustration for me over the last 10-12 months. I'm going to buy these (if they are in stock) and install them this weekend.
