Clutch?
Clutch?
Anyone have any opinions or ideas as to if the clutch is on it's way out? If it is I want to get it done before the lemon law warranty runs out since there is no warranty that covers the clutch.
Mine had just turned 3 and I have 41K on it. I've never had any of the issues you've described above. It's a normal hydralic clutch to the best of my knowledge. Even the little tank under the hood to check the fluid level.
My 2007 behaves as I would expect. I find the clutch smooth and easy to use, nor have I ever had the gear grinding experience you describe, and there are times I drive it pretty hard and throw quick shifts. Are you talking about cables in place of shift linkage, or a clutch cable?
Ok a couple of things to think about............
If you have never driven a car/truck with a hydraulic clutch you may find that you need to push the clutch peddle farther than your used to with a linkage clutch.
Second a cable shifter will not shift as fast as a direct linkage shifter (like an old fashioned 4 speed) it takes a little more "touch". This is really fairly typical with transaxles.
If you still have issues my bet would be that the shift/selector cables need to be adjusted.
I asked the mechanic about the cable adjustment you mentioned because my friend said the same thing. He said there wasn't any such adjustment....
Anyway they are dropping the transmission and by law if they don't correct it this time around either they have to refund my money or give me another one since it was purchased used. I really don't want to give it up since I really like the imperial blue and black interior and the night I bought it ordered a bunch of mods that are actually showing up here today!
Interesting it only does it between 3rd and 4th. If it was a clutch problem, it seems to me you would have problems not only on every shift, but it would be difficult to get it into 1st when you were stopped. Mine was sometimes difficult to get into 2nd when it was new, but seemed to loosen up as I got some miles on it. With 18K on it, its fine now. It could be bad syncro's on 4th, but why only when its cold. Let us know what it turns out to be.
So I talked to the service department at my dealer yesterday and come to find out there was a service bulletin that was just released to them this week. It seems others are having the same problem but not enough are having the problem to warrant a recall. I didn't catch most of what he said since he rattled off a list of parts they had to replace but the jist of it is that there is grinding on quick or steady shifting from 3rd to 4th or 4th to 3rd. They have to replace some of the syncros and forks in the transmission along with various other pieces to correct the problem.
I'm glad I caught the problem before the lemon law warranty ran out and had to pay for such a repair. Thankfully while their bed side manner sucks at this dealership the customer service is up to par and they are going beyond fixing the problem and giving me a new clutch set as well.
