clutch pedal not returning to top.
I have a 2009 HHR SS 5speed. The clutch pedal doesn't return to the top. I have to put my toe under the pedal and it pops back up. Does any body have an ieea what could be causing this?
Thanks Boomer
Thanks Boomer
There could be an issue with the return spring or the pivot for the clutch pedal is sticking
https://www.chevyhhr.net/forums/hhr-...-clutch-42360/
X3, check the spring. I had this issue a while back, here's the thread.
https://www.chevyhhr.net/forums/how-...dal-arm-55769/
(OK. A little weirdness on the site. I posted my 1st response and Oldblues post wasn't there. Now it is with a time stamp almost an hour before mine.
What gives Oldblue ? Are you messing with me using those Mod skills ?
that causes the pedal to fall.
