clutch position sensor
Old Jul 7, 2015 | 12:30 AM
Meltingside's Avatar
I just got the error code for my 2010 SS and noticed sometimes my throttle sticks and cruise doesn't work. I wonder if it's actually the sensor or the harness itself. I've noticed when its acting up sometimes my volume controls on my wheel don't work properly either. sometimes when I push up the volume goes down instead...
Old Jul 7, 2015 | 06:03 AM
What is the code number?
Old Jul 7, 2015 | 09:39 AM
Sounds more like a loose ground wire or a dying battery, the cruise won't work with a CEL light lit.
Old Jul 12, 2015 | 05:20 PM
I don't remember the code, but it said it was the clutch position sensor. Sometimes the cruise works with the CEL light on and sometimes it doesn't work with it off also...
Old Jul 12, 2015 | 06:13 PM
The actual code number needs to be posted. Descriptions alone are generally of the generic kind and can sometimes be misleading.
Based on your 1st post, you've got other problem(s) than a CPS.
Agpullen
Nov 29, 2016 03:41 PM
hobbytrucker1966
Jan 20, 2014 12:29 PM
spike1965
Apr 2, 2013 12:04 PM
B.Diggity
Mar 31, 2012 07:49 PM
sndsgood
Apr 30, 2011 07:18 PM
