Confused about test data, low compression and normal leakdown?
I made a leakdown tester as per Eric the car guy on YouTube. I defiantly had 100psi. Input. I was holding off terring it down further as I have already started it. I am not sure what to do next. It did not start this issue until I had run E-85 gas for a month, which for me is about 9000 miles or more.
You need an accurate leak down test performed. Either modify a cheap one as shown in the link I provided, borrow an expensive one, or take it to a shop. Then you'll know what problem you're dealing with.
I've watched that vid also, more than once. If you did exactly what he did in that vid, you would not have conclusive results. He went out and bought the cheap tester, didn't modify it to make it useable, and then, when he couldn't get it to work right, just fed 100 PSI into the cylinder without any gauges. His test on cylinder 6 only had about 15 PSI, and 100% leakage. His test on cylinder 1 only had about 8 PSI and 50-60% leakage.
Then that went into my brass t and my second gauge. With the connector to my hose to the spark plug hole.
Where did you see the bore scope ad? My care is correct for e-85. I have read some have had issues with it in the south east. I am in Atlanta Georgia.
Ok, back to being puzzled.
Just to be clear... This means you are leaking 10%, right? Gauge starts at 100 and goes to 90? Not leaking down 90%. But I would expect a lot more than 10% on the cylinder with low compression.
I think we were typing at the same time, you may have missed my post about the exhaust valves.
My bad cylinder was at about 75% of the good cylinders for compression, and the leakage was almost 10x the leak rate of the good cylinders.
Your bad cylinder is much worse than mine, just over 50% of the good cylinders, I would expect much, much worse leakage(like 75-100%). I wonder if you drilled the orifice too big, would it cause these results? The standard is .040" or #60 drill bit, or 1mm. If it were larger, it could cause very inaccurate results.
Here is wiki https://en.wikipedia.org/wiki/Leak-down_tester about half way down they talk about the orifice.
I got one of those unsolicited emails. Tmart.com. I'm guessing if they are selling them Harbor Freight might be.
5M 6-LED 5.5mm Lens IP67 Waterproof Android Video Endoscope Borescope Snake USB Inspection Camera
Features Slim and light design, highly portable Connect to Android smartphone directly via micro USB port on the phone Offer a clear view of the interior of machine on cellphone or PC screen The photo and video files can be saved to your Android phone Full-screen app for a clear view and comfortable use
Valid to Apr 25th 24:00 EST, Only 199 Items Left
$13.29 $16.99
$13.29 $16.99
