Constant door problems - any MI HHR specialists?
Old Aug 5, 2014 | 09:27 AM
nk_'s Avatar
nk_
Originally Posted by donbrew
The reason for it sticking is that the wire that the plunger is attached to has gotten itself out of it's guide/channel/place. You have to remove the door panel and look closely at the routing of the wire, there is a bit of shiny plastic where the wire is supposed to rest. If the panels have ever been removed it is very easy to get the wire of it's guide. Been there, done that.
You don't need an HHR specialist, you just need a body mechanic that has an eye for getting it right.
I hope that it's that simple. How do you take the door apart? I mean basic, basic here instructions, the first thing you unscrew is what? Looked at some of the pictures of that one guide. Looks a bit advanced. I don't know enough about cars to doing some of that, although taking the door apart and checking that it is guided or in place I think I could do (or would be willing to do).
Old Aug 5, 2014 | 10:34 AM
Courtesy of the Search Tool at the top of the page: https://www.chevyhhr.net/forums/prob...speaker-43402/
Old Aug 5, 2014 | 10:40 AM
No offense, but taking off a door panel is basic mechanics.
I would suggest subbing the job out to someone with the know how or basic mechanical ability.
Old Aug 5, 2014 | 11:01 AM
nk_'s Avatar
nk_
Talking
Shockingly, I am NOT offended. Why? Because I'm not a car guy! :) My concern of taking the door off is not being able to get it on properly or everything tightended, etc. It would require some risks for a non-car guru.
Old Aug 5, 2014 | 01:05 PM
firemangeorge's advice is good - taking off a door panel can lead to breaking a few things if one is not careful. and a torx driver is needed, which not everyone has hanging around in their tool box (at least they aren't expensive though).
Generally speaking - if you can take it apart, you SHOULD be able to get it put back together.
On a difficulty scale of 1-10, I'd rate the job as a 3 (lowish difficulty)
Old Aug 5, 2014 | 02:14 PM
The guide I was talking about is basically a shiny bit of plastic.
Old Aug 6, 2014 | 10:09 AM
prod's Avatar
Are you talking about the rod that the door lock knob is attached to? Mine just flop around freely once the interior panel is off. Any pictures of this plastic piece?
Old Aug 6, 2014 | 12:45 PM
LawDog88's Avatar
Originally Posted by Lucky
https://www.chevyhhr.net/forums/prob...-23231/page15/ Look at post 127 an 150 for latch/lock tsb's
Thanks Lucky. I was super tired that night and forgot to log on and find that the next day.
Old Aug 6, 2014 | 04:35 PM
I found out the hard way that there is a right and a wrong place to put it back. It's really just a patch on the liner, doesn't look like it matters. It was a while ago and my memory may be in error, but I do know for sure that I had to take the panel off 3 times to make the lock work.
TiggersHHR
Apr 21, 2023 11:59 AM
nybble
Jun 5, 2013 10:28 AM
skyline26
Apr 19, 2013 03:06 AM
Sno White
Tires & Wheels
Oct 30, 2010 10:07 AM
HMSTitanic
Jun 19, 2008 06:38 PM
