Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
I had the same issue finding information about the Moog problem solver bushings , they couldn’t tell me which way was up on those either.
All those letters and numbers stamped in them but not the word UP nor DOWN
These are awesome, last along time , like 4 or 5 times longer then the rubber bushings
Ive seen those. If/when I have to change again I will use those. I already had mine on order when I saw those. In fact I ordered oem then I found my local autozone had the moog solid bushings in stock. So I picked them up when I went to get the press.
