Coolant filler cap very hard to turn
Old Oct 11, 2021 | 07:50 PM
My coolant filler cap is extremely hard to turn. When loosening, it's easy for maybe 1/4 turn, then there is so much resistance that sometimes I think I won't be able to get it off, and I'm pretty strong. Very hard to turn going back on too. I've cleaned both threaded surfaces in case the threads were gummed up.
Old Oct 11, 2021 | 08:02 PM
RJ- Mine is tight too, I just left it be..
Old Oct 11, 2021 | 10:03 PM
Plastic on plastic threads + pressure/vacuum. I always have a 4 inch slip joint for the job (BF water pump pliers).
Old Oct 11, 2021 | 10:56 PM
Silverfox's Avatar
How about a little silicone grease on the threads ??
Silverfox
Old Oct 11, 2021 | 11:09 PM
How about with the metal filler neck, Oldblue?
Old Oct 12, 2021 | 06:57 AM
You could install an aluminium 1 1/4 inch filler neck, much easier to open to check the coolant level.
https://www.fillernecksupply.com/1-1...nsor-adapters/
The straight spout is out of stock, but the next one down will work!
Double check and measure the OD of your OEM pipe, it maybe a different size in the SS
Old Oct 12, 2021 | 09:41 AM
I'll check it out, thanks oldblue!
Old Oct 12, 2021 | 12:40 PM
No problem. Those are less money then the GM plastic
Old Oct 12, 2021 | 07:58 PM
Silverfox
Thanks SF, I just added some on the thread, & nice improvement !
Old Oct 12, 2021 | 10:35 PM
Silverfox's Avatar
Great Sleeper.... Sometimes we tend to overthink the problem !!!
