Coolant tank weep hole
Old Jul 12, 2017 | 08:44 AM
Scouttster's Avatar
While topping the coolant tank reservoir, I slowly and carefully intentional overfilled and I notice water coming out this nub area that appears to be a weep hole? Is that an overfill outlet or weep hole?
Its my understanding, that no part of the reservoir should be open to atmosphere and if any part is there is normally a check valve type gasket involved.. I cant get a clear look - so tight in there..
Old Jul 12, 2017 | 10:21 AM
Never heard of a weep hole in the tank just on the water pump
https://www.rockauto.com/en/catalog/...ery+tank,10457
Old Jul 12, 2017 | 10:22 AM
You understanding is wrong. That is not a reservoir it is a recovery tank. The seal is at the pressure cap on the hose.
It should only come up to the indent in the tank when cold.
Here is a thread about the same subject:
https://www.chevyhhr.net/forums/ss-s...y-20118/page3/
Old Jul 12, 2017 | 10:27 AM
And here is a good pic of where the coolant level should be when cold.
Old Jul 12, 2017 | 10:39 AM
Thanks RJ. I couldn't find it.
Old Jul 12, 2017 | 11:14 AM
I keep thinking it's in the how-to section, but it's stickied in maintenance(where it should be!).
Old Jul 12, 2017 | 04:01 PM
Scouttster's Avatar
Reply
Seall is at the pressure cap on hose..
That says it all..
Thanks
SSROADSTER
43
Mar 7, 2022 08:46 PM
slonny
Nov 7, 2016 06:30 AM
bt0210
Sep 1, 2015 07:17 PM
Diskokid
Jan 2, 2009 12:49 PM
denny
Dec 26, 2006 09:04 PM
