Coolant temp problem
Old Aug 25, 2015 | 09:07 AM
  #31
lw9090's Avatar
I have not replaced the Cap. Curious why that would cause an issue?
I'm hoping it could be that or a bubble instead of a head gasket or something major.
Old Aug 25, 2015 | 10:19 AM
  #32
It is supposed to release in both directions at 15psl. If it doesn't then count cannot go back and forth. Also 15psi raises the boiling temp by a co sidereal amount. Also a tiny leak in the seal may be undetectable.
Old Aug 26, 2015 | 01:31 PM
  #33
Rzrman328's Avatar
Update:
Took the car for a short drive about 15 mins.
Temp gauge working. Fluctuated anywhere from 174-181. Even had it on the freeway at 80mph for a bit.
A/c worked great. Cold air.
No overheating issues.
any ideas or leave it alone? Lol
Old Aug 26, 2015 | 05:54 PM
  #34
Drive it check it in a few days!
Old Aug 26, 2015 | 06:07 PM
  #35
Less than 180F will cause a code soon.
Old Aug 26, 2015 | 06:12 PM
  #36
Rzrman328's Avatar
That's why I came on here askin in the first place....the car has never given a code?! No CEL, nothin. I'm confused lol.
Old Aug 26, 2015 | 06:15 PM
  #37
Drive it if code shows up post it in full we'll be here.
Old Aug 26, 2015 | 06:18 PM
  #38
Rzrman328's Avatar
Will do.
Old Aug 26, 2015 | 06:32 PM
  #39
BUT, the temp display goes --- and the A/C doesn't work. That means there is a code "pending".
Somebody out there is selling mis marked T-stats! If your temp is running 170F-181F, that means you have a 170F T-stat. The running temp should be right around 180F-195F on the highway. Never below 180F.
You are not the first!
Old Aug 26, 2015 | 06:59 PM
  #40
That's one reason I recommend only using GM AC Delco T-Stats, they others can open to soon and cause this problem! The 180 degrees is what the ECM is looking for and to be at by a set time or the MIL lights up!
And the coolant it likes is Dexcool, never overheated Dexcool, not over the expiry date of 5 years Dexcool !
