Coolant temperture sensor keeps needing replaced.
Old Jun 7, 2021 | 08:30 PM
i007spectre's Avatar
Just bought a 2008 HHR with the 2.4 liter and started having issues where the A/C would blow hot and the coolant gauge and digital display would not read. Well long story short the temperature sensor needs replaced. I'm thinking OK it does have 125,000 miles on it.
The problem though is that according to the carfax I got when I bought it the car that sensor was replaced not only in November 2020, but also in March 2021 less than 1000 miles ago.
Is it possible to have just gotten two faulty ones back to back? Or could there possibly be some other issue with the vehicle causing them to fail prematurely.
Please any advice or input would be appreciated.
Old Jun 7, 2021 | 08:36 PM
Probably not the sensor. Much more likely the thermostat that is bad. Use only ACDelco part number 131-158. They may have put the wrong one in last November.
Old Jun 8, 2021 | 06:39 AM
X2 the thermostat is most likely a Stant or some other $15.00 part, the AC Delco 131-158 isn’t cheap , so most shops don’t install them, the coolant might have air pockets and need to be burped.
Old Jun 16, 2021 | 12:54 PM
MN Murph's Avatar
Does ACDelco tstat 131-158 really work in an 2008 2.4 LT?
When I've searched this part online, it says it's not compatible with my 2008 LT 2.4
Old Jun 16, 2021 | 01:45 PM
Try the RockAuto site
https://www.rockauto.com/
See it there bottom of the standard replacement list.
Old Jun 16, 2021 | 03:52 PM
Lonwane's Avatar
MN Murph
The AC Delco is compatable with my 2006 2.4.
I would look into where you are getting your information.
Chevrolet says it is the recommended P/N,
even Amazon says it fits.
Old Jun 16, 2021 | 07:06 PM
And we’ve been recommending it for years, in all years and engines 2.0, 2.2, 2.4 litres
Lake Runner
May 2, 2021 08:46 AM
JamesBorisPerez
Feb 10, 2021 03:24 PM
comandoed
Jul 12, 2020 07:44 AM
ironheadbro
Mar 6, 2020 08:00 AM
TenspeedPops
Sep 30, 2019 08:36 AM
