Coolant Temps Bouncing all over
Old Jul 11, 2018 | 03:41 PM
Cat Man HHR's Avatar
Originally Posted by donbrew
Could be the pump or clogged radiator. I am leaning toward bad pump.
Have the HHR had issues with the pump at high mileage? Like the impeller slipping?
Old Jul 11, 2018 | 06:25 PM
Not necessarily at high mileage, but impellers have been known to stop spinning for various reasons. Chain, bearing, impeller etc. The weep hole being on top in a hole doesn't help you noticing a bad bearing, like you used to be able to do. Plus the impeller is just a force fit onto the shaft.
Old Jul 11, 2018 | 10:04 PM
gio89kid's Avatar
Really, hmm. Mine does the same thing, but only on hot days and after driving it hard up a long hill.
I changed the coolant and thermostat and it stays 178-190 all the time except on really hot days where it does what this person is experiencing.
I know I did not add enough water to my coolant mix so I will be replacing it again soon.
If it was the pump would’t It fail to go back down in temperature at a stop?
Old Jul 11, 2018 | 10:07 PM
gio89kid's Avatar
Oh, I see. He said it rises when he is not moving.
Does it rise when you are not moving after you drove it hard? Or just all the time like in slow traffic?
Old Jul 11, 2018 | 11:18 PM
maddawg's Avatar
Mostly just in stopped or stop & go traffic. I ordered a new radiator and thermostat and will change out the fluid. I need to get this corrected since this is my work car that I drive all day.
Old Jul 11, 2018 | 11:45 PM
gio89kid's Avatar
ah, well hopefully the new radiator, thermostat and coolant cures your problem.
Otherwise I would have to agree with them, the water pump may be failing.
Best of luck! :)
Tip: use premixed 50/50.
Old Jul 11, 2018 | 11:51 PM
gio89kid's Avatar
Not to steal the thread but, does anyone make a full aluminum performance radiator for the HHR?
Old Jul 12, 2018 | 05:42 AM
Don't use anything but the proper AC-Delco thermostat and Dexcool... You don't want to have to do this twice.
Old Jul 12, 2018 | 08:41 AM
maddawg's Avatar
I have a Delco radiator and thermostat on order. I will probably just buy the pre-mix. What is the total capacity for coolant>
Old Jul 12, 2018 | 10:14 AM
Premix Dexcool, I buy two, one gallon jugs, leaves a bit for burping the system and top ups if required
